Okay, I've tried fixin this bugger 3 times now and I just can't keep the steering knuckle boots on. I have a M36A2 and was recently greasin everything up underneath when I noticed one of the boots was torn. I bought 2 new boots with zippers, ring clamps, etc. The first time I put them on according to the directions. The zippers are facing the direction the should be, end result with the zipper clasp inside the boot, and all siliconed up. Took the truck up to our ranch (2 hours offroad driving), came back and the inner rings slipped off. Put them on again, siliconed everything up again, went to the ranch again. Came back, the inner rings were off again. The last time I put some 3M gasket adhesive on the ring notch, tightened the rings as hard as I could get them, made sure the rink bolts were under the protective plate, and went to the ranch again.
Guess what, came back and they were off again.
Can any of you think of what the H E double hockey sticks is going on? My 2 thoughts was #1, something is snagging and pulling them off, but I couldn't see anything that would. The second is that due to the zipper model, it is not able to seat itself correctly, which allows it to slip off.
Any help is greatly appreciated as I need to go to the ranch again
