cant start a M1008 with batteries
84cucv1ton
New Jersey
two sets of charged batteries, glow plugs check out. i had to move it, i put jumper cables on. starts right up.
fully charged batteries could barely crank it over. i checked what i know. nothing worked. what could i be missing? i have no clue
thanks for the help
CUCVFAN
Gunner's Mate First Class
54
Jarrettsville, MD
Dirty terminals? Clean the inside of the cable ends and the posts of the batteries with a brush. I had a truck that had some grease on the terminals and they had to be TIGHT to get good cranking power. Apparently, that grease was non-conducting... :roll:
JohnFire
Pottsville, PA
Also check all large power connections and the vehicle ground. Losse connections can do the same as low batteries and dirty connections. I saw the same thing with a brand new truck that when I wired all of the emergency lights on it I didn't torque the ground down enough. I get afraid of breaking studs off. It would only start on jump or intermittent but kept acting like low batteries.
