Capacitor Assembly Identification
cmroles
Phoenix, AZ
Can somebody identify this component for me? The closest I could find was "Capacitor Assembly" on Page 54-1 of the -20P TM.
There appears to be 3 capacitors held together by a bracket attached to the driver-side firewall right next to the windshield washer pump. In my truck the capacitors are bypassed (harness plugged into itself).
Should I be concerned about this, or is it something leftover from equipment (radios?) that is no longer installed?
cucv1833
Lake Charles, LA
theres a thread on here called "Make your wipers go fast-er " i read saying they bypassed the capacitors to make the wipers go faster. have a look hope this helps.. mine are still connected they said it works. someone will chime in for a proper answer
Warthog
232
OKC, OK
Tese are indeed capacitors/noise supressors for the Military Radios.
There are many of them on the CUCVs.
Unless you are running a Military Radio set, they are not neccerary and can be removed.
P.S. - Thanks for attemping to look up the parts before posting your quiestion. You learn more that way.
