Carb Float Material in Mil Std Engines?
m139h2otruck
NH
Any idea of the material used to make the floats in the little mil spec engines? 3 kw gen set would not start on Saturday, with no fuel in carb, but pump was working. Took carb off, and separated bowl (very carefully) and the float was stuck closed by being wedged against the bowl wall. Sanded float (a lot!!) and reassembled. Seems to work, but not happy with reusing float bowl gasket. Will the float now sink due to the sanding? Maybe it swelled due to today's new fuel (10% alky)?
mangus580
282
Western NY
I often wonder if sanding down the float some would help this. This is the only downfall to these engines... that crazy carb.
peyton
10
houston, tx
Re: RE: Carb Float Material in Mil Std Engines?
acetomatoco said:
ya all gotta go to www.saturnsurplus.com and get a new carb for less than the cost of 3 Starbucks Supremes....
Except that their floats are the same crappy material and will do exactly the same thing. Been there, done that. Unfortunately it is not the answer.
Peyton
peyton
10
houston, tx
Not to be too negative but I tried sanding ... just opens the pores and it swells up again. I even tried to seal the float, after sanding, with POR gas tank sealer, that didn't work for long either. I think the only solution is to relieve the float bowl as much as possible with a grinder. If you come up with something that works, *please* share it.
Peyton
