carburetor needed
JDToumanian
14
Phelan, CA
Have you called Antelope Valley Equipment & Truck Parts yet? I don't know for sure if they have it, but they have a lot of WWII parts....
661-945-6788
Jon
paulfarber
19
Gordon, PA
If you have the proper air cleaner I would go with the 28AV11. Its a civvy carb, so that means that parts are widely available. The cast iron carb was military only, and parts/rebuild kits can be a bugger to find.
Unless you take your truck off road you will not encounter the issued that lead to the cast iron carb.
THE CARBURETOR SHOP / Carburetors for sale by application lists them for sale.. but I have no idea if the list is up to date.
68t
55
Michie, ,tn
I got a nos zenith updraft carb. cast iron. with governer, not sure what it fits. if anyone need one.
paulfarber
19
Gordon, PA
If you can post the numbers off the ID disk that would be helpful.
Most zenith carbs are impossible to identify without the ID disk numbers.
paulfarber
19
Gordon, PA
The site does print 'No want ads' across every page.. every single one (in the 'notices' box).
Technically, isn't every question a 'want ad'? :lol:
porkysplace
1,487
mid- michigan
This form the rules page;
Do not post items For Sale or items Wanted in the forums.
this post isn't a question about a part , it's a ad , as DrGreg noted
paulfarber
19
Gordon, PA
OR compatible carb.
To me that's a question, which I answered.. but since the forum patrol may not have read that I will leave it as a homework assignment to find out what IS a compatible carb.
The original poster did not know.
Maybe if you gentlemen (used loosely) would contribute rather than complain (and they call me negative) we would learn something instead of trying to be some sort of weird mall cop on the internet..
So, back on topic.. what other 'compatible' carbs will fit a GMC 270?
RealCavDog
12
Joplin, Missouri
Guess we need a lesson on the difference between "want" and "need " !
And I may be wrong, but I never saw a question in the first posting ?
Or could it be that since someone had an answer, to a question unasked, it makes it right ?
paulfarber
19
Gordon, PA
I believe the question of 'or compatible carb' needs answered. I mentioned the 28AV11, but there are several of the 28AV series that will work with somewhat reduced power (smaller jets/venturi)
The Carter W-1 used on the Chevy will work (thats what my CCKW had on it). The air cleaner will fit the cast iron carb, also.
See that class.. we are learning! Whether you like it or not :)
robert c neth
Banned
233
girard pa
this works for me ,i was looking for a carb for my cckw besides the one that is on their and now i have my answer.thanks to the question and the answer the search is over.
