Myrtleman
- 6
- 3
- South Carolina
Hi all. Replaced my carrier bearing today on the front propeller shaft because the other one was falling apart. I noticed that the old bearing was angled just like the new bearing after installation. Bearing was installed correctly and the shaft is perfectly straight so I’m a little bit stumped. Wondering if this is normal? Would greatly appreciate it if one of you guys can take a look under your rig just to verify. The bracket that the bearing connects to appears to be perfectly fine, never hit or damaged. Rig is a 1097A2 if that matters. Thanks for the help.
