CAT 3116 Emissions output data
High Water
I am on the search for the emissions output report for the CAT 3116 engine that is in the M1078A0. The engine is manufactured to EPA regulation of 1993. I cannot seen to locate the actual emissions output values. The values I am referring to are EPA tests on CO[SUB]2[/SUB], HS, NOx, and Particulates; maybe other measurement. Typically this data is submitted with a certificate of conformity from the manufacturer to the EPA but these being auctioned military trucks there is limited documentation and Stewart & Stevenson may have had some compliance exemptions.
I think any CAT 3116 engine certificate will work, therefore documentation from a Chevy or GMC Kodiak truck with this same engine would list the same data as long as the manufacturing year is early to mid 1990’s.
Can any of you help me find this data?
Thank you in advance.
