Cat 7155 Clicking on M916
JohnJuan
Hickory,NC
Cat 7155 Clunking on M916
After reading multiple post, on the Cat 7155... If you could help me problem solve that would be great. Here is what I'm dealing with, the transmission shifts great in my M916 but it clicks! The faster I go, the faster it clicks, until I get into 8th gear / middle range then it starts clicking slow and speeds up like before, until I start the high range gears. There is no air hissing or leaks. I did take the umbilical cord off and put air tool oil in the holes as well as in the air line prior to the transmission attempting to alleviate the clicking. I also topped off the transmission oil as well, good color with no burnt smell. This truck is new to me, picked it up yesterday. Any help would be greatly appreciated!
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Post a video of the sound if you can. Pull the floor access panel for a better vantage. More than likely it is the rear roller bearing but a click vs a clunk can be a huge difference
JohnJuan
Hickory,NC
It does! How do I deactivate that?... The switch is off in the cab. I was going to video in the morning but that is the sound!!!
simp5782
9,339
Mason, TN
That is a broken gear in the main gear section of the interaxle. You need to know which axle is doing it so you can replace it. It is very very pricey to fix. I think around 1000 for just the chunk but you need to lnow which axle. So you will need to Jack it up off the ground and figure that out
The interaxle switch is on the dash. It locks the front tandem and front axle in together. It should be flipped down.
JohnJuan
Hickory,NC
Well... It appears it's in the transmission. The clunking seems to come from the rear main drive area. The transfer case and all axles are quiet. The clunking was there in rear wheel drive and all wheel drive. Also, do I have lockers? All rear wheels are in drive on both sides no matter if I'm in rear or all wheel drive... I'll post 3 videos of everything.
simp5782
9,339
Mason, TN
Yes. The truck has lockers.
More than likely you have a broken spring in the rear clutch assembly
simp5782
9,339
Mason, TN
Is the PTO disengaged? Just to double check.
First diagnostics procedure would be to remove the rear driveshaft,
depressurize the air in the system. Then spin the output of the transmission and see if you can feel the clunk with spinning.
The next step would be to pull the valve body off. It would probably be a pain on a 916/20 though. You might be able to undo the rear cab mounts and the drivers side mount and lift the cab to pivot to be able to remove it. I don't think there is enough room thru the access panel. You will need to check and see if any of the gear plates inside are broke off on their outside ears.
Or you can remove the rear clutch housing and check for a broken spring. You will need to remove the driveshaft, remove the rear transmission mount and remove all of the outer bolts on that rear housing. They are 9/16 or 5/8 sockets. Do not remove the interior circle of bolts. Remove the clutch housing from the transmission. Prop the clutch housing up and spin it by hand and see if it is in there. If you feel it there report back
https://youtu.be/F3MGNKTdQWY
