Mark Buller
- 9
- 8
- Darlowo, Poland
Can anone help me with a problem I am having with leaking air (via the most forward--when mounted in the truck--air vent cap) on the rectangular shaped transmission shifter block, mounted on top of the 7155 Xsmn. Air is leaking profusely, immediately upon pushing in the (air supply) Xsmn engage knob on the side of the Cab Xsmn shifter/gear selector (of course after waiting until the truck has built up at least 100psi air pressure) Is this a stuck poppet valve or a faulty O-ring or? or? Most important is how and what must be done to "FIX" this problem? The post about mounting an additional oiler and pressure regulator on the rear of the outside air tank is... done to preclude such a problem? i.e. dry sticking poppet valves?
