So, now that I've started work on my CCKW, where are your best souces for parts? Doing a 2 1/2 ton isn't like doing an MB where you can pretty much build one out of reproduction parts. (did one about 17 years ago)
I'm starting with the engine (as posted in another thread) so those are the parts I'll need first.
I plan to to the rest of the drive line next to fix all the leaks etc.
The chassis & body will be last (closed cab truck). I'ts pretty rust free...the only spot I noticed is the bottom front cab corners under the fender. It must never have been run in salt as all the bolts have come apart very easily, even small screws in sheet metal.
Not sure how detailed the rebuild will be. I don't think I'm going to do a full on show truck restoration....don't have the time and $ for all that, but I'd like to do a good mechanical fix up and make it look nice.
