CCKW Tcase swap to M135?
mv135
Milford Ma.
Hello,
Does anybody know whether a CCKW banjo axle transfer case will fit a M135?
I am mostly concerned with the alignment of the input and output shafts(driveshafts)
I think it might , but I have no experience with the CCKW Tcase.
Also is there more than one model of a CCKW banjo Tcase?
I will be looking for a CCKW tcase if it is compatible with the M135, so if any are for sale,
reply here or PM me. I will be posting this in the early deuce forum also.
Thanks,
Ken
NDT
6,486
Camp Wood/LC, TX
I do not have firsthand knowledge of this swap other than knowing it was widely done by surplus dealers in the distant past. The driveshafts are in the same or very similar locations on both cases. The jackshaft U-joints are completely different and will require a custom built jackshaft. The remaining U-joints are the same between the CCKW and G749. There is only one type of GM CCKW transfer case. You have to be very careful buying these used, as the ball bearings will wallow out the soft cast case and then you are looking at expensive machine work to fix the case.
saddamsnightmare
80
Abilene, Texas
March 27th, 2016.
Just for thoughts:
Why not see if an M35A2 Transfer will fit, at least then you can dispense with the sprag gears in the M135 transfer case that cause all sorts of problems in a rollback (if you are in "D", bad things happen). This should also get you the air shift on the front axle.
AMGeneral
115
Connelly Springs, NC
March 27th, 2016.
Just for thoughts:
Cannot do that in a GMC deuce,the front axle turns in the opposite direction vs a M35.
saddamsnightmare
80
Abilene, Texas
March 28th, 2016.
Learned something new, I guess you'd have to introduce an idler gearbox on either the front or rear driveline to solve that piece of GM engineering!:wink:
