a68cudas
- 0
- 0
- Brookfield, Ohio
Id like to put a center console in my 1009 can any of you guys share some thoughts, suggestions on what you have used or bought and any companies that make consoles for this style blazer.
I like that, very creativeHere's mine. A 20MM ammo can. The height is perfect!
LMC Classic truck parts, heres the linkSimonckr where did you get that headliner?
Nice seat covers.....I went the 30 mm ammo can route and it looks really good. I'll take some pics tonight but here is one from a outside the door.
blitzengine, how did you find a lock cylinder that works with the CUCV key? I tried my key in the junkyard console I got and it wouldn't even go in, much less work.[/QUOTE
I got mine from a junk as well and my key would not go into the lock either because of the corrosion inside the lock tumbler. To make things easier for you should get WD40 or something similar and squirt some the inside lock then insert the key into the lock with the teeth facing the left side of the console (see picture) if not you may end up with a broken key. You will have to work the key in and out several times to free up the tumbler, it will take some time and patience. I want to let you know when you finally get your key into the lock you will not be able to lock it because the key is not coded for that lock, but don't loose hope there is a solution! Take the console to a locksmith and he can pop the lock (do not try to pop the lock yourself you will break it) and code the lock to work with your existing key . This is what I went trough to be able to lock my console using my existing key and it is cheaper than buying a new lock and carrying an extra key on your key ring. Hope this help.
