- 2,035
- 221
- 63
- North West Arkansas
I changed oil and fuel filters on the 5 ton, fuel filters were in terrible shape, especially the secondary ones(hard to reach to change). Oil filters looked pretty good, I let the truck sit for about two weeks to drain the filters. Only had to add a quart or so of oil. Issue is prior to filter change idle oil pressure was about 30-35lbs now after running the engine for about 20 minutes it is steady at 60-65lbs at idle and 85lbs at 2000rpms. Will this settle back to 30lbs. or is this where it should be????
Thanks,
James G.
Thanks,
James G.
