choll
- 5
- 18
- Las Vegas,NV
Im changing the oil cooler lines on Monday, oil filter to raidiator, anyone have any suggestions before I jump in. Napa had the parts in stock.
The oil filter adapter has a paper gasket and o-rings between itself and the block. I've had oil leaks from there. Napa sells a small block oil filter adapter to engine block mounting kit, comes with all the paper gaskets and o-rings.Well just changed the lines took about an hour no issue. The old one were leaking because they didnt have o rings in them. I guess I have a spare set now. That was only part of the oil leak. I have a leak near the exhaust just above the replaced hoses. Anyone have any ideas i cant see what would be leaking. I am also going to post this under oil leak.
