Changing to diesel on a old M52 tractor.
movcondude
11
Holstebro, Denmark
This issue has undoubtly been on the forum before havent been able to find it though.
Does anyone out there know what has to be changed beside the obvious when instaling a LDS-465-1A Turbo Multifuel powerpack to an old M52 gasoline fitted tractor ?
Ex. can the fuel tanks be used or does it require diesel ones ?
What does it takes ?
Thanks in advance
eagle4g63
34
North/west Indiana
The tank can be used....you are going to a multi fuel so gas won't hurt anything.........you will need to install a fuel shut off cable, the one on the dash that hooks to the Injection pump so you can shut down the motor.
