coachgeo
- 3,404
- 113
- North of Cincy OH
Add in below post your .02 on searching out such gremlins. Thanx in advance.
Chasing Parasitic Battery Drain
Came across this corny KISS video and did some follow up reading of reviews on it.... most seem to support it's information as being valid. As for doing this with 24v side??? Here was suggestions I got when asked.
. Use Ohm's law-
(very helpful ) but then again there is feed a man..... or teach him to fish. Eventually, will do some fishing to learn more. Good brain exercise.
. Use 2 of whatever was in the video in series.
sounds logical.... but it is illogical to "assume" this is sound logic
. You don't need a resistor, connect the positive lead to the negative terminal and the negative lead in the negative battery cable and read the "amperage "
verified with Peter who posted this that "yes" he does mean + & - in same path on a Negative line. Confounds me
Hope it helps folk.
https://www.youtube.com/watch?v=B__DqK90IIc
UPDATE 1.
here is another with more recent info (2015) and goes beyond parasitic drain. have not read reviews on how accurate the info is
https://www.youtube.com/watch?v=QRso1A0VScw
. Use Ohm's law-
Hope it helps folk.
UPDATE 1.
