Check out my new tool!
Keith_J
1,317
Schertz TX
Nice! Did you GTAW that yourself? What filler? All that Cr-Mo would scream over-alloy with an ER309 to offset brittleness unless you PWHT but that might affect box end durability.
FMJ
37
Las Cruces, NM
I provided the pieces to a professional welder, he told me he used stainless for the weld, not sure about the details, but it does hold in a test to 180 lb/ft ;-)
Bighurt
46
Minot, ND
Buy one and try it if it breaks its craftsmen get your money back... guarantee man, gotta love it.
The Snap on ones are rated at 2000 in/lbs...
Keith_J
1,317
Schertz TX
ER309 is over-alloyed 304 stainless:-D.
Keith_J does weld;)
swbradley1
Modertator
1,686
Dayton, OH
Is it because it will slip off or what? If it is because of the slight offset you will have the same problem with this box-end welded to the socket extension. Not doubting you, just want to know.
I myself could never bear to do that to any of my Craftsman tools. I'd buy a throwaway set from Harbor Freight or Northern.
sw
Bighurt
46
Minot, ND
A Crows Foot Wrench will not work for the Head bolts by the injectors.
Yes, I would like to know how to calculate for the offset also.
C=D(A/A+B)
A=Length of wrench (measured from center of lug to center of handle)
B=Length of adapter (measured from center of lug to center of nut)
C=Torque Wrench setting
D=Desired torque at fastener
