wreckerman893
Possum Connoisseur
- 15,626
- 2,037
- 113
- Akenback acres near Gadsden, AL
While I was resting and celebrating Robert E. Lee's birthday on Monday I decided to see if the engine that powers the Chemical Shelter trailer would fire off.
Myself and Freight Train had made a successful parts run to Double Deuce's place near Montgomery on Sat. I scored an original 24 volt battery that fit in the battery holder on the trailer. I added acid to the battery and made sure it had a full charge.
I got the battery mounted, made sure the engine turned freely, and sprayed some Marvel Mystery Oil into the cylinders.
Since I didn't trust the original fuel tank not to leak I rigged a temporary one using a lawn mower tank. I had freed up the frozen throttle linkage and bypassed the old fuel line and an electric fuel pump that also sent fuel to the multifuel heater mounted on the trailer.
When I gravity fed the fuel into the engine fuel flowed out of an orifice just in front of the choke butterfly.
I had my son push the start button a few times but it never fired off.
I then put the tank lower that the carb to keep the raw fuel from coming out of the choke and I wasn't sure the fuel was going to the carb. A few more tries and then I gave up to keep from draining the battery.
This is the Hurcules 4 cylinder, air cooled, 85 CI engine that was used on a lot of military equipment to include air compressors, generators and maybe the Mule.
Does anybody have any experience working on these engines???
What size spark plug wrench pulls the plugs?
If this engine runs I may can recoup a large portion of my investment in this trailer.
Any help would be appreciated.
