Civilian alternator for gen 1 temporary..questions
FrankenCub
30
Broome Co., NY
For the time being I have a new civi alternator to go in place of gen 1. It's purely a need the truck now deal. I can't be down a few days waiting on parts to arrive. I will be rebuilding the original this summer.
I see references on using a civi alternator but they don't expand on it much. I assume the original ground wires can ust ground to the case, but what about the push on connector? Is that going to need a ring terminal to go to the positive on the alternator, or taped off?
It's bolted on and ready to be wired right now.
Keith_J
1,328
Schertz TX
The brown push on connector is the tach signal for the STE-ICE port diagnostics. The alt for the front battery needs the two pin connector and the ring term for the battery. The two pin connector supplies switched battery voltage and the lead for the malfunction indicator light. The right side alt needs isolated negative.
FrankenCub
30
Broome Co., NY
That's what was throwing me for a loop was the STE-ICE connector. I seen the same pin on other alternators besides these isolated ground alternators, so when the new one didn't have it I was thinking I got the wrong one. I looked for hours trying to figure out what was up and kept coming up empty. A friend at NAPA was searching to see what he could find and happened across a post here that said it was for the diagnostic connector. Instant relief lol. She's all good and charging again. When I have time I'll rebuild the original and put it in a box for later use.
