Civilian Equivalent of MEP804A-B Fuel Level Switch NSN 2910-01-376-2268, 88-21121, 134230, M3465, 10455-1
screejunk
10
Vermont
Does anyone have the Ohm range for the fuel level switch on the MEP804A-B? Looks like 24v and 8 inches would do, but not sure of the Ohm range. These are the details I have:
ACYRDC Voltage Rating24.0 volts nominal
ADAVOverall Diameter1.250 inches nominal
AFLWActuation MethodBuoyancy
AGAVEnd Item Identification6115-01-274-7388
BBJXMounting PositionVertical
BJKHLiquid Type for Which DesignedFuel, nonaircraft
BJKNFloat Effective Travel1.000 inches nominal
BJKQTank Insertion Length8.078 inches minimum and 8.328 inches maximum
Light in the Dark
5,894
MA
Military units are available for $30 on fleabay. Search ' Fuel level sender sending unit M3466 134240 10455-2 88-21121 2910-01-391-636' if you want to find them.
