Civilian equivalent of mil. Lubes
recon
verbank,ny
Is there a list anywhere on the site that gives civilian equivalents for military lubricants? At the end of LO 9-2320-209-12-1, for example, there are 6 different lubrications listed but I have no idea what they would be in the civilian world. It lists general uses such as chain lube oil, or gear lube oil but no weights.
recon
Divemaster920
Banned
494
VA
For your differentials, transmission and transfer use GL-1.
For your bearings......Just use the cheap stuff. Your bearings should not be over 130F, no need for the high temp.
chgofiveo
Chicago IL
Mystik JT-7 for your differentials, transmission and transfer case...it is GL-5 and meets with the MT-1 specs... It is OK to use with Yellow metals... I checked into it
chgofiveo
Chicago IL
how is Mystik product..15-40 diesel engine oil?
any good?
dose it match up to the mil LO Spec
I never used the Mystik eng oil... only the gear lube and was very happy with that. I used it for topping off Diffs, Trans and T Case... My neighbor uses the Mystik synth blend in some of his old John Deere Tractors and is very happy with it.
