I was messing around under the dash of my truck yesterday installing a keyed ignition switch in place of the original accessory switch. I needed a way to connect the new switch to the original wiring. I didn't have any military wiring connectors, and no way was I going to cut and splice into the wiring of my beloved Deuce.
I found the following connectors at my local NAPA store (I'm sure you can find similar connectors at any decent auto parts store) and they worked perfectly! The one on the left side of the photo is a NAPA/Belden #784341 .157" Blue PVC male snap terminal, it snapped into the female military connector as well as, if not better, than a military male connector, and the price was only $1.83 for a pack of 20.
The one on the right side of the photo is a NAPA/Belden #784353 .157" Blue Nylon female snap terminal, it also fits as well as, if not better, than a military female connector, and the price was only $1.83 for a pack of 10.
Don't know why the female connectors were more expensive, probably Nylon insulation vs PVC insulation, but they only had the males in PVC and the females in Nylon.
With military connectors going for $1.00 each, these are a pretty cost effective substitute. Of course for exterior applications they are not watertight, but for locations where they won't be seen a juducious use of a quality electrical tape will solve that problem!
BTW, DON"T try to find these connectors at NAPA on-line, neither the part number nor a keyword search for Belden will find them!
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=5982
