Civy heads
i beleive there r 2 different heads the hummer/ g van/bus heads and then the pick up/tahoe/suburban heads i beleive the difference is somthing with the angle the intake manifold bolts on go so as long as u got the same angle u should b good to go
1,824
I'm trying to think back to the last time I had a 6.2 apart. I don't think they needed to move the pump to require it to be readjusted. Heads should be able to be R&R with pump in place.
73m819
329
gainesville, ga.
r is spelled are
u is spelled you
b is spelled be
FROM the SITE RULES
Do not post as if texting and do avoid the use of texting abbreviations. We are not the grammar police but we want everyone to easily read your post in at least 8th grade English.
