Civy Ignition switch
Alredneck
Banned
1,494
15
TN
OK i got the way to hook it up but does any body have a wiring diagram for me to figure out wiring a ignition swith to the deuce through the old accessory switch and include the starter feature with it. I went through some of the older post and got the wire numbers but when i was under there yesterday i didnt see where they were labeled so i figure a diagram would help trace them down. Many thanks.
Alredneck
Banned
1,494
15
TN
Yes i see, i see! I was hoping to get rid of the acc switch but easier makes more sense. i will just put in a battery disconnect so no ghost loads drain my batts. I was thinking of running a 12 volt source so i can run my cell charger, cb, grms radio and such with a keyed hot but another disconnect will probably easier. I also dont want a bunch of butch wiring goin on so a circuit breaker and terminal board will need to be installed. Many thanks
cranetruck
75
Meadows of Dan, Virginia
Re: RE: Civy Ignition switch
My 757 is wired without the accessory switch, the "Master Switch" has "OFF", "ON" and "START"(momentary) positions.
Note that the switch isn't drawn correctly, but those are the functions and the "civy markings", "S", "R" and "B" added by yours truly.
