Clamp thing next to stack
jimm1009
71
Louisville, KY
Part of the ring mount and almost all trucks have them.
I think that it was also used for other stuff since not that many had guns up top bumost had this mount.
I hope someone else witll chime in here.. Good question you have there.
jimm1009
WillWagner
2,707
Monrovia, Ca.
Gimmie a week, I can post a pic of a ring mount installed on my junk :cool:
sandcobra164
289
Leesburg, GA
Mine has it also. I have the leg that goes in that clamp for the ring mount as well. If anybody needs it, it's free minus the shipping charge. I'll remove it and send it to you at once.
Westex
El Paso, TX
You got a pic of this thing. I might make it worth your while; we're in a serious war with the feral hogs in this state.
Westex
El Paso, TX
Nothing like "Ma Deuce" to clear out a herd of hogs........you hit them with that .50 cal and you don't even have to field dress them.
Yes sir. And I know you have them in Alabama. But they are wreaking havoc in Texas. Fewer hunters, etc....It has reached a stage whereby I have actually overheard ranchers and farmers state that it is irresponsible NOT to shoot them.
cessnatwin
30
seminole/florida
Simple I just took mine off and threw it away! It is part of the mounting racket for a non turbo truck! the stack hooked onto it, someone must added the turbo if it is factory the truck!
Stan Leschert
90
North Vancouver, BC, Canada
Gotta be the ring mount. Our M-135 has a similar thing. I will talk to a couple of vets who went through the CF M-135 Veh Tech course and get back to you as soon as possible.
If someone smarter than me can answer faster, I would appreciate it! I normally just clamp a flag there, but it is looking like a real sporty place to hang a convoy light!
panzerjunky
san diego ca
It is for the M66 ring mount
One of 3 mounting points the other 2 are on the rear corners of the cab then those legs support a ring that weighs a little over 435 pounds not including .50 cal M2 its
ammo or a gunner leaning on it so yea they are stout.
Take care
Jerry
