Cleaning Canvas Seat Covers?
mhb285
Paso Robles, Calif.
I need to clean the Passenger canvas seat cover. Its in good shape, with no holes in it. How can I do it without shrinking it?
Just a little soap in cold water and hang it dry ?
I'm open to sugestion.
Mike Bogner
papercu
31
Baxley, Ga.
cleaning
Depend on why you need to clean it. Wayne
From the manuals:
Canvas that has mildewed can be cleaned by scrubbing with a dry brush. If it is necessary to use water to remove dirt, it should not be used until mildew has been removed. After removing mildew, examine fabric. Look for evidence of deterioration. If canvas has deteriorated, it should be replaced.
Mildew must be removed with a bristle brush before canvas paulin can be
properly cleaned and aired. Wash with warm. soapy water and dry with soft cloth.
oil or grease? use Saddle soap, warm water, soft brush, and dry rags.
WillWagner
2,606
Monrovia, Ca.
RE: seat
Aw, just put someones butt in it with pants you don't care about. Drive around 4 or 5 days, and it'll be clean! :wink:
1,807
RE: seat
Rust is going to be a PITA to get off. Might try some oxolic acid in a remote area to see how the fabric reacts. No guarantees.
mhb285
Paso Robles, Calif.
Well I hand washed it it cold water and a little detergent. Then rund it up in the shower to drip dry.... Looks pretty good. Lot of dirt on it. I'll put it on on Saturday.
