This thread is just what I was going to start. There's no substitute for blind luck!
I'm in the process of changing or re-packing bearings, replacing all seals, and re-building the wheel cylinders. Rears done; fronts next [also new boots there]. I'm going to change the fluid as well...DOT5.1 to DOT5. Wheel cylinders are not being re-connected until lines have been flushed with alcohol and new fluid is in the MC.
The
only brake issue so far has been slight leaks at the cylinders on the rear rear. So, the questions are:
1-Do I need to re-build the MC and the older-version air pack while I'm at it? I note that a re-build kit is about 37% of the cost of an NOS new-style pack.
2-If no to #1, can I just drain the MC and fill the pressure bleeder with alcohol [?denatured from HD/Lowes ok?] to flush the MC and lines? Re this, I do not want to run the alcohol through the cylinders unless absolutely necessary. I'll plumb all of the lines together with Tygon tubing to a single discharge point, but I have no idea if this would get me a complete flush. We'll see.
I need to get this beast on the road asap for a long boat 'recovery', so I prefer to defer anything that can be deferred until later, like the MC and air pack re-builds.
Comments/suggestions?
bs
