cleaning up the fuse panel
dstang97
30
Clover, SC
Is there any special tools to clean the contacts on a fuse panel? I am starting to have problems with some stuff in there. I'm loosing lights and not realizing it until later.
ODdave
lansing michigan
sounds dumb but works great, aluminum brightner, then rinse with water. dry with the air compressor then hose it all down with WD40.
rlwm211
Guilford, NY
If you have an electronics supply in the area you can get a can of "contact cleaner". The stuff used to be known as "tuner cleaner" when everyoine had rotary dial tv's . The stuff is expensive but it removes the corrosion and then leaves a coating that inhibits corrosion after it evaporates. The stuff is pretty smelly so I would use it with the doors open, and probably put some newspapers on the floor underneath to catch the excess that runs off.
Hope this helps.
RL
1986Blazerk5
Brighton,MI
Hope this helps.
RL
Is this the stuff you are talking about? They have it at O'rielly Auto Parts for $5.99 a can, i have used it before and it works good
CRC Industries 5103 - QD Electronic Cleaner | O'Reilly Auto Parts
rlwm211
Guilford, NY
That should work fine.
As I recall the fuse panel has the plug in type of fuses and they are 1/4 inch lugs. You can use a piece of sand paper folded in half to clean the terminals if need be if the cleaner does not work.
2cents
RL
