Clearance lights and fender turn signal indicators
Wildchild467
57
Milford / Michigan
I have never seen that style as clearance light on the roof, but i have seen those once as marker lights on the sides of a box. Did they ever use those on a Deuce? Was there a special harness that the military used for those lights?
Steamynachos
Calgary Alberta
Yes you can use them you just have to splice into the wireing harness for the light switch find the wire that turns on the head lights and tap a wire off of there. All Canadian trucks have clearance lights with some sort of hack job with wires running all over to them.
Snarky
9
Brazosport, TX
I used the civilian counterpart of those lamps with 24v bulbs for side markers on my deuce. I would say you probably wouldn't want them on the roof as the way they tend to mount makes them harder to waterproof, lamps meant for the roof tend to have a more robust rubber gasket.
