I mostly had this problem licked, but since I am doing some work under the engine, I thought I'd have another look. A couple of years back I replaced the starter with a Wilson MT28. I also replace suspect wiring to be sure there was no hidden corrosion clouding the issue. Now that fall is here I have been getting more of what seems to be a starter gear (Bendix) that hangs in the flexplate sometimes. I say that, but I am not sure- Whenever this happens and all I get is a loud clack (sounds like the starter, or maybe from behind the lower dash, I can try turning the key over and over until something frees-up and I get a crank, start again. If after I have tried to free the starter with multiple key turns, and I don't get a cranking of the starter, I get under and loosen both mounting bolt. I hear a loud metallic clunk, tighen up the bolts and she starts right up. But see what happens at 19 seconds
https://youtu.be/Me0KiKucnVI
I have just checked the clearance between the starter armature and the teeth of the flex plate using a 1/8" drill bit. There is about another 1/8" of play. I check the mesh of the teeth with a small paperclip and get easy clearance, but it is looking pretty close already. If I put another shim in to get the gears tighter, I am afraid I'll get more binding- AND that first measurement with the drill bit will be even greater.
Any ideas?
Any ideas?
