Clicking on ignition every so often
JeremiahAK907
Fairbanks Alaska
So good ole sandys been giving me some headaches every so often when I go to start it there's a clicking. Thought it was the stater relay so went ahead and did the dog head relay by God is that thing loud!!! But anyway it only does it every so often maybe couple times a week but it'll crank eventually after a couple times. I'm thinking maybe the starter is going out but it's relatively new. Maybe 6 months at most. Also have done 12 volt conversion bash me of you will haha. Any suggestions welcome!
richingalveston
120
galveston/Texas
check your glow plug solenoid. may not be working right, will click. will cause slow start
that's if it is turning over and not firing
if it is clicking and no action from starter then yes probably starter.
check all connections, could just be loose
