Clunking when turning
rccollin
Carlsbad, New Mexico
Im having a lot of "clunking" when turning, both left and right. Im thinking it may be time to replace the kingpin bushings. Anybody else have this issue? Tie rod and draglink ends appear to be good.
rustystud
2,852
Woodinville, Washington
Do you "feel" anything in the steering wheel ? Could be the steering gear itself. I would jack-up the truck (use jack stands) and have someone turn the wheel for you while you go and try and hear or feel anything loose in the steering system. Also once it is on the jack stands, get a long pry bar ( at least 5ft ) and put it under the wheels and pull up on it. If the king-pins are loose the wheel will move up and down. The wheel will also move up and down if the wheel bearings are loose or going bad. You cannot have more then 1/4" up and down movement (Federal Standards) . If you do then you must repair it.
Also have you checked your lug nuts lately ?
camoyj7
wonder lake IL
While its jacked up grease the spring bushings. Better to have axle hanging so the lower part of bushing get grease.
When bushings are a little worn and haven't been greased they will cause a clunking sound when turning.
1,808
Could it be coming from the back? If so, its a common issue. The springs keep the axles centered but the box on the axle has extra space for articulation. Space equals clunks.
152
Birdsboro Pa.
The last time I drove my Deuce I heard a clunk in the front end. I knew my wheel bearings were in bad shape. I had cleaned the and re packed them to buy me some time until I could rebuild the front axle. Now I am putting the axle back together with all new bearings, bushings and seals. Should be finished by the weekend. After inspecting all the consumable parts I have determined that my clunk was the left wheel bearing. The king pin bushings were in ok condition but they were replaced any way.
I hope this helps.
Mitchell.
sandcobra164
288
Leesburg, GA
Mine clunks when turning right off the pavement onto my dirt road. Front and both Rear axles have been checked and serviced by myself. I think Recovery4X4 has likely figured it out. My truck will make it's 5th 200 mile one way trip to the GA Rally in a few months and I'm not worried about the axle staying under it. If you find something different, I'd be curious to know what you find.
welldigger
15
Benton LA
First and foremost make sure all of your lug nuts are tight. I had a front tire coming loose on one of my one tons the other day. Left turns made a horrendous clunking noise. Front left tire had all 8 lug nuts coming loose.
Then check the front wheel bearings and u joints inside the knuckles.
If it was kingpin bushings you would notice severely uneven tire wear on the inside edge of the front tires. That area would have accelerated wear.
dmetalmiki
2,027
London England
Second that. That's what I would definitely check for first.
