abh3
- 3
- 0
- Florala, Al
Well, tonight I finally got around to pulling the engine for replacement and found that the 6000 mile truck has what looks like an 80,000 mile clutch on it, not much left to the 'pucks' and the four finger pressure plate is pretty worn, mabye even 3/32 gone where the clutch ran... So much for just a swap out so is there an easy part number for the clutch and pressure plate or is this a rebuild deal? The flywheel on the replacement engine looks good and I have an almost new throwout bearing so that's not the issue, just the disc and pressure plate...
If it's a rebuild deal there are some reline outfits aroud her but is there a quicker alternative at a somewhat reasonable cost?
Also, this truck has two brake boosters on it, unlike the the other one I have, what's up with that?
Thanks for your time.
