Cold air intake mod?
Duecer187
Arkansas
I have searched and searched but I have a 1970 model m35a2 with the d turbo and I was wondering if anyone has made a cold air intake for their deuce and if it filters enough for the engine. I would figure it would give it a little more air and make the turbo sound a little better? The only things I could find were for the old suburbans. Any help would be appreciated thanks
WillWagner
3,161
Monrovia, Ca.
Isn't it already a "cold air" intake?? It hangs out outside the engine compartment and is in the direct flow of air over the vehicle.
WillWagner
3,161
Monrovia, Ca.
Nope, it goes directly into the filter housing. Put a restriction gauge between the filter and turbo and see what kind of restriction is REALLY there. Spec is 25 in h2o max at rated load and speed
The King Machine
Vancouver, British Columbia
My motivation for changing the air intake was related to function in water.......I snorkeled it. I made brackets that piggy back off of the exhaust stack mounts. My first try at making a snorkel was successful but was a home made jobby. Didn't look that great but functioned well. I put on a ram air style intake on the top of the snorkel. I didn't like it. Showed no real gains as far as performance and my EGT's and boost stayed relatively normal. The down side was it sucked rain water up that seemed to pool in the bottom of the air filter housing. Not ideal. Also on over grown trails the intake would clog solid with leaves, enough to trip the alert in the cab.
since them I went back to the mushroom top. Here is a thread I put together if you want to see pictures.
https://www.steelsoldiers.com/showthread.php?89517-An-American-Deuce-in-Canada&highlight=
Karl kostman
922
Fargo ND
Like Will said the cold air intake is already on the truck, maybe you need to explain just what you think you need and what you expect to gain from it?
Karl
Duecer187
Arkansas
Well it just seems like air will travel less distance less restriction so it would make my d turbo sound better and maybe get a little more air? Just curious what people have done and if it made the engine and turbo sound better?
rustystud
3,376
Woodinville, Washington
Are you wanting to "eliminate" the heated intake manifold ? Yes hot coolant flows around the air intake manifold, but since it is a short distance I don't think it heats-up the air all that much. Since your running a "Turbo" your flow will be basically the same no matter how you change the intake flow. Now if you get a larger turbo then yes you could benefit from having a larger intake as your intake volume would be higher and the larger intake would help with flow restriction. Of course if you somehow do eliminate the stock intake you will loose the advantage the heated intake manifold gives in cold weather. Remember there is always a "give and take" when modifying your engine.
Floridianson
2,528
Interlachen Fl.
Myself If you are talking about the air filter housing leave it alone. Hook up the air compressor intake to the air box housing for fording and clean you compressor air filter while your there.
Best thing you could do I you are looking for something to do is install a air dryer into the system.
