Cold Start
1,172
Worked for me.
It's like a fire breathing dragon with the intake tube off for visual access.
About how many pumps on the primer was that?
1,172
So, just a constant pump with pressure until it was up and running?
Super!
Gamagoat1
Kiowa, Colorado
Yes. Just keep the pressure above 80 psi.
Three things usually keep this system from working.
1. the Glow plug has been hooked up to 24 volts. It's a 12 volt connection and 24 volts will melt it.
2. The Cold start relay isn't working. It's rebuildable, just take it apart clean the points. If it isn't burnt out it should work.
3. The battery that your hooked up to is low on charge.
