Hey guys, I have a 1970 m35a2 and I've noticed a few leaks. The engine was suppossedly just redone like 3000 ago but that was 10 years ago. Anyways what are some common leaks on these engines and drive trains? I have notice the oil pan seaping to a drip. Oil pan was loose tightened it up still does it so I'm sure that will be on the list soon. The ip was also leaking oil and fuel supposedly it was just rebuilt too and I found loose bolts on it. I tightened them up still leaks so I have the gasket kit for it. The main one I'm worried about is at the back of the engine where it mounts to transfer case. It's a slow leak. Do bolts normally come loose on these old trucks like this? How many of you deuce these trucks with small leaks? Any help or insight is greatly appreciated thanks!
