Comp. 80gal., Air, Eng. Driven NEED TM!
No.2Diesel
11
Huntington, NY
Hi,
Events happen in pairs. Less than 48hrs. after picking up the Fermont 30KW gasser generator I acquired this:
Compressor, Reciprocating, Air, Engine Driven, Tank Mounted, 15CFM, 175psi
I have been looking for the exact TMs all over the web and have found some for similar compressor models but not for this one. Does anyone have these TMs in .pdf floating around in their hardrives?:
1.) TM5-2805-20314
2.) " "-24P
The only pic I could find of this model is from Coleman's Surplus.
I've gotten the 4AO32 engine to run (somewhat) but have to clean out the miniscule fuel bowl filter screen assembly and fuel tank. It has a very distinct airplane engine sound to it...brrrm.....brrrm...Ready for takeoff :p
Lieutenant
57
Michigan
It's a Champion compressor, great unit. The TMs you need are:
TM 5-4310-277-14, TM 5-4310-277-25P for the compressor and TM 9-2805-262-14 & TM 9-2805-262-24P for the engine. They should be available from tpub.com
You should also contact Champion to get the factory manual for the R15 pump.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I agree. I have that same compressor head powering my shop. They rock. A search for Champion r15 will bring up alot of info.
