EO2NMCB
- 23
- 18
- DeSoto, MO
Been using the TM-34, also did a search, but did not find much. When the truck was running it sounded like compression coming back thru the intake. Also alot of blue smoke out of the even cycls. Pulled the intake and vavle covers, all valves moving, push rod and rockers arm look good. When cranking with intake off, pink wire pulled, did not feel or hear compression coming back up? The rubber in the torsional damper looks good, did not look out of round when cranking. Any ideals before I have to pull the engine?
thanks all in advance.
