Barrman
- 1,734
- 113
- Giddings, Texas
Got the engine all buttoned back up, got oil psi while spinning on the starter, got spark at the plugs and fuel in the carb. We get a puff,puff, puffffff every now and then. But, what we don't have is a running engine. Since we only messed with the head and head gasket, I started thinking about rings and valves.
We pulled all the plugs, put a compression tester in one and let the engine spin with the carb wide open. 25,30, 20, 25,20,20 were the results of all six. That sure does seem "throw the engine out" bad to me. But, I don't know flat heads as well as I should. For an OHV engine it is awful. What does a 230 flat head normal post for compression psi readings?
Thanks.
Oh, we haven't done a leak down test yet and I know a little oil in the spark plug hole will really boost those numbers. I am waiting to see what the compression psi numbers should be. If these numbers aren't that far off, then we will go ahead and see which leaks more between the valves and rings. Otherwise I will call the owner when he gets back from vacation and start talking about a repower.
Thanks.
