Compression reading
Tony
Camarillo, Calif 93012
Took a compression test on my M-135 GMC engine.
First reading and then squirted oil and took the second reading..Are these readings ok ? or must I do some engine work?
Cyl # 1st reading 2nd Reading with oil squirt
1 125 140
2 115 125
3 115 120
4 130 136
Thanks,
Tony
5 121 139
6 135 135
1,131
Looks ok to me for a typical low compression gas engine, but what does the TM call for?
Tony
the manual does not state any specific compression spec..It does state that 30-40 lbs difference in the total is not a comcern
The increase in compression after the oil squirt, is telling me something,,Should I be concerned?
