Confirmed- Tuff Stuff D-Ring Fits
rodent
Denver, CO
Which D-ring is correct?
I needed a new D-ring since I had one that didn't match. 3 of mine look like this:
Tuff Stuff 6.5 Ton Black D Ring Bow Shackle 7/8" W/ 1" Pin 14,500lb Capacity
TS-BS65B-BK
Cost - $16 plus shipping
BUT now when I look at other pictures, I see other CUCV's with different D-rings with the cotter pin. Which one is original? Left has cotter pin, Right looks like the one above.
rodent
Denver, CO
Thanks! One of the previous owners must have installed 3 aftermarket D-rings. I was thinking they were original but its the one cotter pin version that must be original which I'll probably sell.
rodent
Denver, CO
One thing I like about the screw in D-ring is they fit snug on the mounts and don't make any noise and little more difficult to steal if you make it tight enough with a wrench.
My original military D-ring had a thick cotter pin through it and it was a bitch to remove with needle nose pliers. It was like a standard cotter pin you would use on a wheel bearing or tie rod. I don't believe it was the original pin. I think a pin like this would be easier.
https://cloudfront.zoro.com/product/full/Z2HJuufo5oy.JPG
I think this is what it should have from the military. Correct me if I'm wrong.
https://thumbs.worthpoint.com/zoom/...-m1008_1_445a27df73276a0b34408287e54f89f6.jpg
Sharecropper
987
Paris KY
The cotter pin type make it much more difficult to steal the D-rings. I've had to give up on every one I tried to take home with me.
1,808
Deuce and 5 tons use the diaper pin design. Shackles off the back of a 5 ton will fit a CUCV.
Tinstar
1,775
Edmond, Oklahoma
Bought four from Tractor Supply made sure one would fit before bought them !!!View attachment 723695
Pictures very blurry, but if that’s what I think it is, someone can steal that in about 2 seconds.
The original shackle pins with cotter keys, while not immune to theft, take some time and effort to remove.
If that’s just a regular pin in yours, someone can have all four of them off and be gone in less than 30 seconds.
73m819
323
gainesville, ga.
TS-BS65B-BK
Just so you KNOW, the top picture IS a THREADED PIN SHACKLE, NOT a D-ring, as used on military vehicles, it is called a front or rear LIFT SHACKLE, the reason for calling it a front or rear lift shackle is because some fronts and rears are different. It helps to call a part by the right name.
rsh4364
15
greensprings ,ohio
On my older 1009 I bought original lift shackles. They clunked around a bit, so I put these on front and rear. 20160228_095558_001.jpg 10 ton tow strap, 3 ' cucv. Bought from gemco57 on ebay years ago.
Ilikemtb999
45
Denver, CO
I think the cotter pins are harder to remove than those locks off the lime green ones. Small locks can be busted off with a pry bar and cut like butter with bolt cutters. Meanwhile those darn cotter pins take forever to get out of the hole.
