- 10,861
- 747
- 113
- Front Royal, VA
Following the manuals, and the LO, and watching other work on their trucks, and doing maintenance on MY trucks, I am confused. Do the outer bearings on the deuce wheels get their lubrication from the main differential housing 90W, and it gradually migrates out toward the bearings as the axle turns, OR do the bearings require special regular attention NOT taken care of by the diff. lube?
When I pulled a rear axle shaft to repair the outer shaft seal, I assumed that since the shaft went all the way to the diff, that the lube from the diff. would make its way back to lube the outer bearings. Am I wrong?
