I'll be renting a Sullair 185 CFM diesel powered compressor and a Schmidt 100A or 300A Pressure Pot to clean some equipment trailers I have. My question is how much media can I expect to use?
I live in a remote area and I'll be blasting outdoors. These are equipment trailers, 4 total. One is a 22' tri axle gooseneck w/ steel deck, the other an 18' tri axle bumper pull w/ steel deck, another is an 18' tandem axle with an oak deck (removeable), and the last is my little 4'x6' single axle utility trailer with expanded metal (mesh) deck. The tree bigger trailers range in width from 6' on up to almost 7'.
The 18' bumper pull is really rusty w/ some areas showing significant corrosion. I will be welding "patches" in as well as whole new hanger kit for the axles.
The gooseneck is in really decent shape with most of the original paint on it but some light surface rust.
The 18' tandem is in excellent shape but showing signs of rust beginning. The owner wants it shot though and repainted while I'm doing my trailers.
I'm trying to get a rough estimiate as to how much sand I can expect to go through. For all the safety gurus out there, I will be using a pressurized hood.
Thanks in advance for any help and let me know if I need to provide any additional info.
Phil
Phil
