Continental MPT 81 tires on M35A3 ?
dkconfiguration
Bangor, ME
I was wondering if anyone has any actual experience with the Continental MPT 81 in 365 80R20 (43-inch Unimog tires) mounted on a M35A3 ? Can the same CTIS wheels be used or would you need everything replaced if not going with the original Michelins?
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
The stock M35A3 wheels are 20x11" MPT and fit perfectly, for those tires. IMHO, the 365 Conti MPT81 is the best tire you could possibly put on your truck.
  • Like
Reactions: HDN
HDN
4,924
Finger Lakes Region, NY
I would've gotten the Continental MPT81s to replace my old 14.5R20 Michelin XLs. Unfortunately they were way outside of my budget, so I went with pre-loved 395/85R20 tires with 75% tread instead.
The 365/80R20 tires are a direct replacement of the 14.5R20 tires. Your CTIS will still work the same way.
dkconfiguration
Bangor, ME
Ok thanks, good to know. The original Michelin tires are very weathercracked all over, in the tread area, etc. They have more than half tread, hold pressure and drive great, but I would not trust it anywhere interesting worth taking, so need these Continentals.
  • Like
Reactions: HDN
dkconfiguration
Bangor, ME
One more thing - The local shop is good to go on doing the tire swap, but they couldn't remember if there is an o-ring on the wheel, and if it is 1/4 inch or 5/16 inch ? Is this anything to worry about?
HDN
4,924
When I did my truck's tires, I used these o-rings:
