OverkillTASF
- 6
- 8
- Central Virginia
As I stare down the barrel of possibly another MEP-831A with a faulty inverter, amidst thoughts of tearing into the inverter and rectifying the alternator output for high voltage DC use in a solar setup, I wonder... What would it take to make this work more like a MEP-016D...
The first and most obvious problem for me is that I have no idea the signals that the speed controller and governor actuator make use of... But I know the speed controller depends on input from the PMA or inverter, both of which would of course be removed in such a conversion... So, engine shutdown (low oil, etc) becomes the first hurdle. The governor on the engine, as part of the Yanmar engine, can easily handle keeping the engine running at the 3600 RPM necessary for 60hZ power generation... But how do we shut it off... Shutting off the fuel pumps clearly isn't enough... I assume we have to actually move the throttle assembly...
Owners of MEP-016D's, or people just generally familiar with small diesel engine generators... What hopefully simple part enables engine shutdown? Seems like something would mount easily on the existing standard L70 bracket and press down on the throttle level in the same way as the governor actuator... A simple solenoid seems like it would do the trick, but I'm having trouble finding what looks like a suitable part that costs less than $200...
