Converting wheels to standard valve stems
3one5
Northern Colorado
Has anyone converted their wheels to standard valve stems? Thinking it would be pretty easy to drill out the rectangular hole to accommodate a standard valve stem. If you have done it, what hole size did you drill it out to and what valve stem did you use?
Thanks,
Coug
4,239
Olympia/WA
I haven't ever heard of anyone doing it.
Are yours leaking or something else wrong with them that you can't just use what it's designed for?
3one5
Northern Colorado
I was hoping to get something that I could buy locally. The rim I have for my spare doesn’t have a valve stem and I’d like to take a spare with me this weekend.
Coug
4,239
Olympia/WA
It's generally considered a bad idea to modify wheels in any way unless you are a professional engineer. I doubt just drilling the hole out round would cause an issue, but way too much liability if a wheel fails for me to say it's a good idea.
Just a thought, but take the spare with you anyway, and if one of your tires does fail, have the tools with you to remove the front portion of the wheel off the rim, and just swap that front plate over to your spare tire if necessary, plus an air compressor to inflate it.
The tools and air compressor are a good idea to have on hand anyway if you're planning on taking your truck off road. All you really need are the air compressor, a socket, ratchet, and torque wrench, and take a copy of the torque sequence with you. A pry bar and a hammer to get the wheel half off the tire rim is also a good idea, as they tend to stick.
If your spare is a different bolt pattern, do the same thing but you can steal the valve assembly instead of just swapping the wheel plate.
another option is AAA+ towing, so that you can get your truck home (well, depending on how far you are going; I have the 100 miles towing and there is a 200 mile option)
Mogman
8,984
Papalote, TX
I have not heard of anyone doing this and of course would not recommend it but there are two basic size holes for valve stems
.453" and .625"
You may find it hard to drill true as that bit will likely walk around that keyed hole, and have never measured one to see if it is even possible.
Mogman
8,984
Papalote, TX
Also if your spare has the run flat in it you will have to unbolt the wheel halves because the run flat will prevent you from simply breaking the bead and inserting the valve stem as you would be able to do with a civy tire/wheel
