What better time than this old time winter to hunker down in the shop, wood stove going, and work on an A/C installation. After my first summer with a M916A1 and frequent envious glances at the descriptions of the $ unobtainable A2 and A3 versions with A/C, I started to look at the options.
Checked with Freightliner on the long list of parts needed for the conversion, the used t/o options, and the interesting straight DC powered units. All were possible ways to go, but without a lucky find of used units serious $ were involved. While thinking all this over along came a SS classified post from Tony(tbanks) of recent production Red Dot A/C kits for the M915A2. Knowing that the A2 version of the M915 was the Freightliner/Detroit 60 equipped line haul version of the M916A1, I jumped.
The kit was designed for the armored cabs and since it was a field installation it came with everything - tools to cut the hoses, protective wrap for lines, oil in the compressor, even wire ties to finish the job.
The freightliner is a quieter cab than my 5 ton, where the ear muffs are within reach, but with the temperature extremes and full throttle hills I decided to strip out the cab inside and reinsulate. Removed the cab liner and the factory open cell foam and put in a three part layering of anti-vibration strips, composite insulation and then closed cell foam. With the lining out it was easy to adapt the evaporator mounting bracket to the non-armored cab and then install the ceiling unit after finishing the insulation.
The evaporator unit contains the fan speed controls, thermostat, and cool air ducts.
