Cooland Tank Replacement
rhurey
15
Bothell, WA
So, how much trouble am I asking for with these bolts?
PB and an impact gun, or some safer way to pull them out?
simp5782
Feo, Fuerte y Formal
9,511
Mason, TN
Cut the bracket and weld your new tank bracket over the existing. Cause we all know with exhaust bolts. They break and become a headache.
Sent from my SM-G860P using Tapatalk
73m819
329
gainesville, ga.
Do not use a inpact, you WILL break the bolts
Spray PB blaster, let it soak in, spray again, let it soak in, do this 3 or 4 times.
Hit the head of the bolt with about a 3 lb hammer, do this 3 or 4 times, spray again between hits (hard hits).
Try to move the bolt with a wrench, NOT a breaker bar, tap the wrench with the hammer if needed.
If no movement, start over, the trick is to get the PB blaster into the threads, when you reinstall the bolt USE anti-seize.
I had to change my tank on my 73 m819, I did it WITHOUT breaking the bolt.
Scar59
42
Mt. Eden, KY
Follow Ron's advise, a little patience and a lot of PB Blaster. Make sure you use a 6 point socket. I've gotten those and exhaust muffler flange bolts out with no problems. Lots of PB Blaster.
