- 5,259
- 3,971
- 113
- Charleston, WV
Hey Gang,
I want to install a coolant filter kit on my 8.3CTA Cummins. I have flushed it out numerous times with water, but it still has a nice rusty tint to it. I have switched to 50/50 since the temps have been dipping down towards freezing.
Since it has a fuel-burning heater kit installed, I plan on using the hot water heater hookups. My question is, which do I use for the inlet and outlet on the 8.3?
Also, I was thinking about using some clear hoses to hook it up at first so I can see how clean the water-coolant mix is getting. I will switch to regular heater hose before any road use. Anyone see a problem with that? It's rated for 60 psi at 80* or something.
I think I will pull the thermostat too for the time being. That way it will circulate all through the radiator and clean out as much crud as possible. If I had to bet, I would say my new thermostat already has a lot of sludge on it.
Any bets on how quickly the coolant filter will plug up? I figure I will take an extra just in case. That would be another good reason to use the clear hose at first I guess.
Comments? Thoughts?
Comments? Thoughts?
