- 215
- 80
- 28
- Rushville, IN
I am installing a coolant filter today along with a block heater. I know there are several threads on others that have done it and I have read through most. The easiest way for my setup is to use the hose going from the trans cooler to the block. I think I can remove where it attaches to the block and attach it to the inlet of the trans cooler and then run another line from the outlet of the cooler to the block. I am unsure of the flow of the coolant though. Does this sound like it would work?
